This tab is not available for hardware platforms with only fixed configuration; it is available for platforms where you can install modules in slots, for example, a Versatile Interface Module (VIM).
- In the Device Physical View tab, select the module slot.
- Select Card.
- Select the Card tab.
Card Field Descriptions
Use the data in the following table to use the Card tab.
| Name | Description |
| CardType | Displays the model number of the module. |
| SerialNum | Shows the serial number for the installed module. |
| PartNumber | Shows the part number. |
| CardAssemblyDate | Shows the date the module was assembled. |
| CardHWConfig | Shows the hardware revision. |
